Has anyone used these products...?
Car shock absorber spring rubber damping rubber cushion rubber "B" type of,Suitable for spring clearance is 35 mm free shipping on Aliexpress.com | Alibaba Group
100% High Quality 2 x Car Auto E Type Shock Absorber Spring Bumper Power Cushion Buffer Rubber Buffer Shock Absorption-in Suspension from Automobiles & Motorcycles on Aliexpress.com | Alibaba Group
When to change ATF of Aqua
Honda Fit CVT Fluid (HMMF) is changed at 75k, as it start showing maintenance error....
In Aqua it should be CVT-F instead of ATF and should be changed around 50 -60 k, being on safe side....
Usman i think this rubber is good for JDM cars. it can overcome the soft suspension issue in JDM cars. It will make the coil a little harder to press. The suspension will thus be able to handle more weight and avoid hitting bumps. thoughts..?
It will make the height of the ride to increase and also decrease suspension sounds on bumps etc... Nice thing to import... Available at aliexpress....
My Aqua.Achieved average After Refuelling & original Airfilter trip from Scheme3 to H-10 Isb Via peshawar Rd & kashmir highway & back.
Awesome
Whats the procedure of importing it ?
Are you importing one..?
U need debit card for online payment...
No orders yet...
One observation I have made from the Photos of Hana Plus...The Hana Plus Variant seems to have a black glasswoll padding under the bonnet hood which acts as a noise absorption medium. Other variants seem to be missing this.
Yes hana c and hana plus have this padding under hood... It can be found in local market to fit in other variants....
AoA
I have just got passo 2012 YururiIts trunk remains unlocked even after locking the car.I will be thankful for any suggestion or reference of a reliable mechanic in Islamabad.
There must be some electrical problems, the wiring should be checked in the trunk region... Sorry no idea about electricians in Isb... But it is a simple job....
New addition to the car for my little one...
Better avoid theseAs they are fragile and break sometimes when load in car and u hit a deep hole in road and then ur car will be lowered from that side and suspension making bad sounds till u replace it , better stick to aluminum spacers my suggestion
brother need your help with fixing the issue of backache due to bucket seats of my 2007 vitz.
can u suggest a solution?
How can i flatten the seats or straighten them to support the back. have tried using molty back care however couldnt address the issue as expected. link to my vitz is below
https://www.pakwheels.com/forums/vitz-yaris/246868-got-vitz-al-hamd-u-lillah
Best thing is to change the seats... For that u have to do a some effort in going to Sultan ka Khoo (or send some friend or cousin or brother or colleague), and find appropriate seats as your requirement... The seats of new vitz are very comfortable, my suggestion is to exchange your current seats with them, seats of Toyota Aqua are also similar to vitz... I think this exchange deal will be best for u...
Self Edit.
