lol.
jz from the way i see, you've put in a wrong combination of items! i keep convincing you and hamza to first make up your mind of what you want.. you wanna listen to Trance, and you're all set up for rap/hip hop.. your current setup is more of spl rather than sql.. if you wanted sql, kenwood sub with kenwood amp was the best for you! type R is specifically meant for lows.. you want more sq with the same or even better level of spl, than go for type X.. 12inch..! or cv..! plus your current amp, sound magus is good for sql as well.. you wont have to change that to get sql, you need to tune it accordingly.
and what are you running your speakers on? you running 718 right? 718 isn't the speaker to go for if you wanna listen to sql, you shd get alpine type S speakers to get in rythem for trance!
and if you want lows, damn you're setup is running fine boy! stick with it...!
