Thanks for the coment on my rig. But I know it still needs a lot of work.
Recently I have been doing some research on the engine options for my CJ.
I did talk to guys from IJC(Islamabad) and 4X4 Engaged(Lahore). A few extremely experienced guys told me to go for the Toyota 5L-E(same engine which appeared in Toyota Hilux). It is a 3.0, but slightly costly. The singapore origin 5L-E is 120K and the Japanese origin 5L-E is 145K in Peshawar. Remeber I already have a Hilux 4X4 transmission in my Jeep. So if I go for 5L-E I wont have to change the box, coz the gear box in my vehicle can fit all L series engines.
If I do go for a 1KZ then I will have to change the gear box aswell.
1KZ without gear box will cost around 85K and with around 120K. So the equation for me remains the same in both the 5L-E as well as 1KZ options.
Now coming to the pros and cons
1KZ is one hellava motor It is a 12 Valve Turbo. It is widely used in the world and australian offroaders swear on a 1KZ. If hooked properly it is wonderful both on and offroad, but it will not slove your basic problem of fuel consumption as it is commonly known as a very thirsty machine though there is a guy I know who has a 1KZ wid manual gear in his CJ in lahore and claims that it delivers 11km/L(though I do not entirely believe him).
1KZ is kwown to deliver not more than 7km/L in city and 9km/L on the highway.
5L-E is a less powerful naturally aspirated version. It is simpler to fix, hook and economical to run. It is very robust as all Toyota Diesels are but will set you back big time in terms of pocket if you go for it. Whereas 2L the earlier version will cost you much less, but it will not deliver offroad.
Currently I have a 2.2 3C turbo in my rig. My CJ wieghs 1475 Kgs unladen which is not much to pull for a 3C turbo. On Highways it is fine and delivers around 14 km/L on highway but strugles offroad as it is a high RPM motor and to get the torque in you need to rev it up. Whereas 2LT is a better choice if you compare it wid a 3CT.
There are some complaints about the 2Ls, from just a few users. But I am not sure. In my opinion 2LT is not a bad choice.
BTW how much is ur 13B delivering in city in terms of fuel consumption?
