Wow matchstickand bhai u leave ur car for 4 days then it will give trouble starting even my new car if i leave it more then 2 days takes time to start !
Can anyone of you tell me how can I prevent moisture in the Distributor ??? after Googling, i found that this start-up problem happened mostly because of moisture in the Distributor.
jxt press the accelerator padle 4 to 5 times before starting. i wz having same issue with my cultus but aftr pressing padle 4 to 5 times it starts on hlf self
brother check the wires for electric current, any visible damage.Also clean your spark plugs.Tunning is also required..
check the distributor cap seal. Replace with a new one if its missing, hard, broken, or deformed.
The cap should clip on tight on the seal.
