Grande brakes are better then sportage. You really need to get used to with it by pressing bit harder then it will feel ok
I had a Grande for 4 years and now a Sportage.Felt no difference in brakes whatsoever.
Grande ABS activates too early in my opinion.
Can anyone please share charges for 10000 km inspection/maintenance of KIA Sportage FWD.
28-30 if air filter doesn’t need changing if it does then add another 9k
I got it done for Rs 14K (FWD). Only oil and oil filter were changed, No Catalytic cleaning required at 10k
Why so expensive only oil and filter change? Cost of oil filter?
The oil filter is for Rs 1900 and oil around Rs 4k. Rest are for the service charges including brake and general service which the dealership refers to as Periodic Maintenance Charges
It means they are looting on so called warranty issue, oil filter is also expensive, I don't think break service required at 10k and also other services and pay heavy amount for one visit
Are these general services compulsory?
Yes their aftersales are not very consumer friendly rather quite expensive. They need to work on robust aftersales including readily available parts and that too at reasonable rates
Next gen Sportage
Oopar wali Punjab number plate ke sath.Neeche wali Sindh number plate ke sath
UK cars have white plates at the front and yellow at rear
It was just a joke
Looks fugly from the front.
Threw me off the first time i noticed
This is just a render, it will not look like this.
Duh?
Render means computer generated graphic. Next gen Shortage is yet to be revealed.
I know what a render is, thank you. The one I've posted above is based on several spy shots taken of the next gen Sportage's test mule. So it might not be 100% accurate but it will be very close.
