Gul and amjad bhai tell me how can I archive more performance out of my bike is this speed is good for my bike or should it could do better.
.bro 87km/h is good and you are very close to do even more.....! simple formula i use for that is only cold weather conditions.... because what my experience shows that in cold bike runs a bit faster then normal because cold air is denser which got more oxygen then normal "more oxygen+fuel=good combustion" so engine produce little bit more power..... this cold air change is very small but helps to run bit faster then normal.......! plus you should chose the day when there is minimum cross winds (normally early in the morning) little cross winds would help you in facing minimum resistance from air while speeding...... plus keep your clothes tight and adjust your sitting position in such a way that it minimizes the resistance of air......... all these little things would surely give you increase in speed....... although this increase would be very small but would surely add 3-4km/h in your speed and even more.......!
But did this 87kmh test on isb expressway at 3 in noon with moderate to no traffic on road but couldn't go above then this speed BTW whats your height and weight
height 5 feet 8 inch..... weight :60 kg......
OK but what are your air and fuel mixture settings as it also make effect on top speed and what is the fuel average u r getting
no mixture is done only when i feel its need to be set...... i do not touch it normally..........! the average i am getting is 35-40 kmpl
Then I think that my mixture setting are set on economy zone rather then top speed because I am getting 45-57 kmpl average will go to mechanic for tuning then I will tell him to get my mixture settings adjusted to get max out of my bike.
Altis your bike is achieving very good top speeds infact its top speed of Pridor 100 so bike is doing very good don't do any alteration enjoy your ravi premium
and Biker99 that is long mileage and in this period tappets untouched is surprising
Thank you amjad bhai now I m satisfied with the top speed of my bike
Suprising.....! i think you are taking it so much surprisingly.....! But bro its truth by the way i am not forcing any one to believe it.....!
Ravi premium 70 with single rider
my yamaha junoon speedo meter always show fast speed 5 to 9 kmph than mobile gps speedometer
Its not a bigthing every bike meter shows higher km speed then GPS but the speed of GPS is way accurate
it means that all motorcycle compnies make inaccurate speedometer for fake speed and worng fuel average
Which bike is it
https://www.pakwheels.com/forums/bikes-3-wheelers/246811-my-new-black-dragon-toothless-camry47
My speedo telling 100km per hour but GPS tells 73 km per hour why is little different about speed
Bro r u kidding me how a gs 150 can go 140km plus
Agreed;)
