8-10k of 1.6 GLX
Rear or front?
Yes i have but in hard format.
Front.They have gone a bit blur and are now attracting moisture on the inside.
Many kind of available if you want to get replace than get the sealed one. As repair one have same issue. Long time ago i asked the front pair was about 30,000.
there is a shop near PSO pump in Chah sultan having Lancer lights and other body parts.
Where are you located? Perhaps if you can let me copy some of its sections and pages??
Bro anyway i can brought from you then scan it and return you.by the way in which city you live.
Belongs from Faisalabad but currently in SOHAR, OMAN
I have the original manual plus the service schedule. I’m in Islamabad.
Cool.. How to get it? Is it in soft copy or hard copy? I am from Rawalpindi.
Can you kindly PM me your Location where in can brought from you if possible then after full Scan i can return it to you
@samkkk and racerali:
I have it in hard form. Send me your addresses. I’ll courier a copy next week.
You still have the service manual? I'm also in isb.
Here you go:
https://pern-my.sharepoint.com/:f:/g/personal/15110002_lums_edu_pk/EgSIN73p7U1LtAc07pagJ5kBXYR1Xnint_Lta_LT17K0Ug?e=zWdW7A
Thanks, I already have that. I thought you have the one specific to CS3.I used these to upgrade retractable side mirrors etc.
The sad part about this CS3A, it doesn't support ELM based scanners. Apparently the OBDII isn't standard. Have you tried it?
I have the owner’s manual specific to both 1.3 and 1.6. Same manual applies to both models sold here.
For compatible obd2 device you have to message the seller on Ali Express to ask whether the device listed is compatible with Mitsubishi Lancer.
I got this one:https://www.aliexpress.com/item/32817153055.html?storeId=405501&spm=a2g1y.12024536.productList_5883562.pic_0
They confirmed it'll work but it didn't. Tried successfully on City, Passo, Civic. Didn't work on the current Cultus (Celerio).
You can use your purchase protection to return and refund it.
