In 99% of the cases ECU?s are not faulty but the problem lies with the choice of the technician, may they be Authorized Suzuki Motors Technicians. They said that they fitted another ECU and vehicle started to work properly. This clearly says that current ECU needs to be updated with new configuration file or maybe something has thrown the currents setting out of Calibration. Ask your current technician to place the ECU back and visit another Suzuki Workshop who has the capability and knowledge to update the settings on current ECU.
Liana?s CNG Kit is one big issue; I have replaced the CNG filter, Cleaned the CNG kit by opening and draining all the oil, cleaned the injectors and cleaned all the fuses installed on this kit, went ahead and changed the ignition coils but problem remains intact. Then I suspected if injectors not being connected properly but cross verified individual wirings on the injectors being labeled as A?B?C?D but all of the going to its right slot as being labeled on Injectors housing as A?B?C?D. Last of all, what remains is Software testing and updating the software with new parameters. I have visited few facilities at Suzuki Workshops but not of them knew how to update the parameters on the software. What I don?t understand, is what has caused the ECU to reset or dump the previous working settings.
It?s obviously frustrating to work your way around with this kit because of lack of available expertise in market.
