For the second problem, go to a good alignment shop & ask him to check the following:
1- Lower arm(chimta) nuts first, if they are loose, then only tightening them & alignment/camber adjustment will be enough to solve ur problem.
2- Lower arm(chimta) bushings, both small & large bushing to be checked properly.
3- Check the steering ends & any ply in steering column.
4- Check both Axles(goda), any ply etc or if axles are loose externally.
5- Check all rubber boots.
Checking & inspection is free of cost & if problem is found he will ask you to get the suspension work done & come back again for alignment. Checking is free of cost OK.
