but again...if water is reducing, what does it have relation with the cap? just a question for my knowledge
A low quality and desi cap can't maintain pressure in the system and leak out steamed water which results in loss of water. Always use a proper new and original cap its way cheap than a blown gasket....
Post pic of you radiator cap
Atlast after khuwari of 3 weeks my Liana is Up and running again...
congratez
History of your car gives a pretty good idea of your car problem you are running your car without theronostate valve and auto fan most dangerous thing fan will never work your radiator cap is faulty as well now shocking news you gaslit was fired due coolant as your car's fan is not working the coolant temp keep on raising and fired gaskit if it would have been water it would escaped due to heat in a foam of steamSolutionChange radiator cap and install theromostate vavle then use coolant if you want
no...oil and water is not mixed...
what i feel is that water is steaming away...probably when ac is used and engine gets hotter than normal
well explained!!
where to get a good quality cap?
axle leliey???? how much for a original pair? its around 10k here in karachi
so, what is the issue if fan is running on auto mode and not direct.? it is usual...
Fan should ve on auto but if theromostate valve is not present it wont work
LIANA Lxi ABS Brakes not working !
aaj subha phir 1 liter paani daala jab k there is absolutely no leak
Ek hi bar tarike se kaam karwalo bar bar pereshan hone se behter hai
Abs check lamp came on ?
Abs brake lite turn on first when I switch on, but when engine starts light become off. The brake pipes r disconnected from abs unit. How to repair/ reinstall abs brake system ?
what about this?
Price?
3.75 liters...
Rs 600
I use the same last summer works well.
