180 for a filter is fine...is it of suzuki make or guard?
Zic A is semi synthetic..can easily go for 6k km w.r.t conditions of Pakistani cities
All 10w40 are semi synthetic?
no idea about all brands...
Its Suzuki made and I have taken my own oil and air filter he said oil filter will cost you just 180rs why don't you get it from us.
Sent from my QMobile i9 using Tapatalk
so they charge for oil change if we take our own oil ka dabba? also, do u have any idea how much they charge for engine tuneup (other than that grabit deal)?
@saboor73 ??
The radiator cap is the one that come factory fitted the dual pipe cap over the resivour bottle is overflow pipe if water is goibg out of it then you have a bad radiator cap
apparently the cap is working fine.
what if we block the overflow pipe? will it help?
Why trying ustaadi? if you block it water will leak from cap just like old cars which had only inlet pipe
How r u sure that holding as much as presure as it should? A slight less and radiator cap will allow the pressurized water to go in to reservoir bottle i would say changed it as soon as possible radiator cap cost 300rs at max why risk your cars gaskit
so what will happen if water leaks from the tank..atleast less tou nahi hoga na
the brand you suggested for cap is easily available in our f b area?
Dhoondna parega fb area mai kuch nhi milta meri bike ka breath pipe bhi sadar we Lana pera tha
other brands not ok?
also. new radiator kahan se milega if i try to find?
This on is tried and test do inquire about this one kya pata mil jai
Duplicate post
