they also refused to tune my engine as it has non ff cng kit
price for new radiator is 35k for liana...
and in market its 4500 to 5500
What connection error? And no direct fan is a big NO. Make it automatic please.
direct fan is ok till the t-valve is not installed back...otherwise car will keep on getting hot
Install a t-valve and make the fan auto bro. If ride heats up with that track the problem. Removing t-valve and making fan direct invites all kinds of problems.
WTH is this are they out of there mind
i dont know but its true....! a uniformed technician assigned to me said that
each and every mechanic, electrician, radiator wala and even the 3s now have said not to install t.valve....ajeeb he chakkar hai
You went to igmotors near incholi ? If you by chance have name of mechanic which told you remove t-valve and direct fan please share his name
dont remember his name
Thanks for detail info.
Can we install AC filter in Liana? by default or by modification?
Kamal hai bhai. Aap ko 3S bhi local mechanic wali he mili.
Sent using Curiosity's onboard communications sytem.
Some Lianas come with filter trays. Mine doesn't and the space for the tray is selaed. I think I will need to change the blower housing or cut it to install the filter.
Cutting is possible and easy but there won't be anything available inside that housing that will hold the filter and won't let it beeing sucked in.
Sent from my HUAWEI G7-TL00 using Tapatalk
2006-7model liana have cabin ac filter dont know 2008 mai suzuki ko kya howa bad mai although swift's cabin filter can be used according skill bro
I have 07 model. But it's sealed. What is the procedure to open it?
No idea of how to open it I had early 2007 model and it had cabin ac filter tray maybe @skill can help you
Here are pictures of my car's blower one with vacant trey and other with swift's filter .Filter can be cut short to fit .Mine blower is little weak so I skip this filter on the other hand I keep interior neat and floor mats always washed so no problem.
Brothers, in above post @skill bro has posted picture of the tray and housing..
My housing doesn't have any tray.. please advise from where i can get this tray.
Thanks
