Bro please read this carefully..
SABOOR BHAI IS RIGHT USE SAE 75W 90,
AND PLEASE GO FOR API GL-4,
MY RECOMMENDATION IS POUR IT WITH SYNTHETIC GL-4 WITH LIQUI MOLY GEAR OIL ADDITIVE.
Dear please share here.
Power steering oil is bottle me daalna hoga aap ko..plz dont fill it till the top or it will leak out of bottle kyu k its a hydraulic system.
Usama bhai never do that the friction reducer from LM is not for synchronized gearbox like Liana gearbox such act will make sync Ring to go bad real quick
Does any member has ff Landirenzo omegas user and service manual in any format. One is present at pakwheel forums but that in hold of scribd dot com that demand approx 10 $via credit card or paypal so that is useless. So I request to senior and helping members if they have then post in this forum. Thanks in advance.
V good info
Thanks brother for your reply. I noted your points.
Thanks Abid bhai
I literally just wrote what the sticker said
That sealer that is mentioned is actually thread sealant - which you can buy from industrial stores, If you want to be super duper cheap then use a coat of indian head shellac on the plugs or even two wraps of teflon tape.
There is a reason the levels are marked hot and cold, overfilling will cause issues.
there is no sensor settings. its a plug and play situation.
the usual cause of failure is wet coils or bad coils - highly aggravated if you dont use proper repair procedure.
ask the brand holder, their office is open in normal business hours.
What is remedy for bad coils? Since genuine new ones are hell expensive, so people opt for side coils etc. Are they repairable?
Get kabli of you cannot afford new ones, plus never wash your engine.
I got your point on antifriction.. liqui moly has the anti friction additivies but i was recommending another one.
plz post the sticker picture plz.
haha........normally, we always keep 30psi irrespective of the weight carrying
Ye lein brother.
Is any member has ff Landirenzo omegas user and service manual in any format. One is present at pakwheel forums but that in hold of scribd dot com that demand approx 10 $via credit card or paypal so that is useless. So I request to senior and helping members like saboor bhai, if they have then post in this forum. Thanks in advance.
