Around 200K. Now it has:
New front wheel pans (taway)
New rear wheel drums
Brand new rear brake shoes + Brand new front disc pads
Brand new shocks (both front and rear)
Brand new sound system + rear Sony original speakers
Brand new brake master cylinder
Brand new radiator + All radiator hoses, including the metal metal pipe that is connected to the bottom radiator hose
Brand new ECT Sensor, Crankshaft Position Sensor, Camshaft position sensor
Brand new coils + brand new original BKR6E11 NGK spark plugs (the exact factory part number for Liana)
Brand new PCV valve + tappet cover gasket
Brand new engine mounts (left and front)
Brand new blower motor actuator (original Denso part)
Brand New front axle rods + outer axle joints
Brand New chimtay + New right rear control arm + new bushings
Brand New driver side master switch (installation was done at home as always
Brand New wiper blades
Brand New brake oil in both brake and master cylinder
Brand new transmission fluid
Brand new power steering hoses + new power steering fluid
Brand new air filter box (old one was broken and held up with a copper wire) + new filter
Fresh engine oil + heavy duty oil filter
Brand new rear mud shields (imported from Japan as original part numbers were not available locally)
And now brand new AGS 85AH battery
Plus, replaced the two leaking fuel injectors with brand new ones yesterday. I plan on replacing the other two next month because they are as old as the ones which were replaced, so they can give up on me anytime. Better to be safe than sorry.
Now the items that remain on my check list are: Front and back bumpers, right rear tail light, and an ac/heater switch as the previous jahil owner had shorted it internally for AC-only which ruined the differential voltage based control mechanism for the blower motor actuator and the previous one had no teeth left AT ALL due to this jugaar).
