Gtg nahi huwa aj?
Mujhe pata nahi yar. Noone contacted
Liana has cabin filter for ac?
Koi filter nikla tou tha
It present in 2006-7 model after that paksuzuki discontinued ac filter
Whats the alternate then?
Yesterday met an electrician-he was literally cursing liana to the max.. Kept saying k kya %?#@ car banai hai, itni gandi, sirf problems, kuch chero tou kuch aur tangg krne lgta hai, maslay he maslay etc etc
Nothing paksuzuki just covered the place with plastic cover
"Nach na Jane aangan thera"
Well m so sorry usama bhai and abid bhai.Today in morning i was having appointment for my Corolla at 10 am Toyota Central Motors.Handed over car to them by 11am and received at 3pm and then reached home took my detailing products and detailed corolla to the max then younger brother was asking Dad to lets have a Dinner outside so we went to BBQ2NITE Malir Cantt.Dad used corolla and me used my beloved Liana came back by 10pm so today this was all my plan.I had the GTG plan in my mind but with the time shortage it was not possible.So me not bothered nor usama and abid bhai.
Well i will be showing you a new DIY which i did recently tomorrow will post the pics.LED Neon under Liana.
Mine is 06. So it should have a cabin filter.ill check it today
Can we use octane booster for injector cleaning in liana ??, will it help or create more problem or useless !
Useless. You will not find any sorf of performance benefit
Octane booster to clean injector ?
Hello Experts,Few days back i had leackege in my exhaust just below the exhaust manifold, what i experienced was very good performance and good pickup stable RPM, yesterday i fixed the leackage and then now car is under powered in low RPM..... matter of fact there are two catalyst converters on Liana one just under the engine maunifold and other one under the car in exaust pipe... what i concluded is the one under the body in exaust pipe is block .. 1) SHOULD I CLEAN CATALYST WITH ACID ?2) SHOULD I BREAK CATALYST WITH ROD?3) SHOULD I REMOVE CATALYST AND MAKE DIRECT PIPE (which will ofcourse increase sound and then i need to put booster muffler at end
Please suggest.
Mine is 07 model but don't have cabin air filter. Is possible to install?
Red line your car in 2nd gear
Which engine oil in Api SN 10w 40 category is orinal and more reliable ?Other then Zic A !
IT will harm my engine ? should i use high octane ?
