It's just normal. With ac car rpm gets high and at idle it is around 900 to 1k rpm.
No. If one of the rubber seals on your piston inside the brake cylinder is losing g pressure, it will result in brake pressure loss but no fluid loss.Fluid loss will occur in case of a leaking line or brake system.
There's probably a micro leakage somewhere. Check the small rubber pipe underneath the intake manifold.
Well i could not find any leakage. May be i should change all hose pipes. Can someone refer a good mechanic near Rashid Minhas Road? I noticed an oil leakage probably a drop on the ground underneath engine.
Why u bypassing abs??
Throttle body service by good electrician
Anything missing sound there aor misfiring??
Brake oil should be at upper level and all the leaking must be terminated and brakes leather shoes should be in good position
No every mechanic says Gari Sai hy, even Suzuki said k car theek hy,but average is dropped.
very beautiful car
الحمد للّٰہ2009 Liana VURV , white LXI version
Car is enough good in some aspects as well
My power steering rack has now started to make weird noises, thinking to swap it with EPS. Has anyone done it before. What is the repsonse and does it results in better fuel mileage and car pick?
Rear wheel piston washers leaking or master cylinder worn out.
Any one about lianas fuel average issue?,
Of there's no issue with the engine, Liana gives better mileage than Corolla XLi of the same year. In city with ac, it should give you around 11.
I agree with you on that, the issue is after changing plugs of my car, it's fuel average got disturbed its giving 6 to 7,somethings messed in my car, can any one guide?
Before tuning and spark plugs it was giving around 12, something is messed up.
The mechanic has messed either the coils or any of the connections. Maybe the spark plugs aren't correct.
Oh OK, I will go tommorow and will get checked spark plugs and will notify, InShaAllah.
Abhi isme bkr6eya-11laga Hua hy, is it right?
