In Liana , I think Using 10w-30 or 0w-40 is good for M13A engine
copied from website
Recommended engine oil 5W-30, 10W-30Oil type API SG, SH, SJ, SL or SMEngine oil capacity (Refill capacity) ~ 3.7-3.9 L
There is no difference in fuel economy of any of the models of Liana in Pakistan. Its the same engine throughout the production run.
But China mie 2018 tk Liana aati rai I think with K14B engine also and u may check
Aoa, is there cabin filter replaceable in liana?
Bro then suggest what we do in the first place for having at least that much mileage...
M13AI think Mileage of 15/16 KM/L at 100km/h is much more better than Corolla or Civic or City as well
Mazarat k sath @ Liana VURV rejectors
Yes. That's too good mileage and that's what we need to know what maintenance we do to our Lianas to get better mileage? Any suggestions and guidance will be highly appreciated.
That is why I mentioned Pakistan.
Aoa everyone , my liana’s steering is making weird screetching sounds when turning the steering rt or left , the sound is apprently cmng from just beneath the steering where horn button is, its not from down, what can be the reason,
I have liana 2008, driven 94000 km, its in perfect condn in my view. The other day i drove it on motorway for abt 600 km with ac and its radiator water was reduced about one and half litre, is there anything i shud be worried abt? Plus which coolant is the best to put in the radiator?
Sir i once purchased my liana’s coil from u, u charged me 5500 i guess, obviously it was a used coil, it worked fine for few days but it again developed the same missing problem, as i had moved from rwp by then thats why i didnt complaint back, but since hen i have trust issues with people who offer their services here
I am sosorry, didnt see the notification, well it is on both, static car and while driving also, it feels like if there is some kind of bearing just beneath the steering whell and it has dried up somehow, i sont know if it makes sense
Have you checked the steering oil?
Your steering's back is rubbing against the steering column cover.
@Haroon Ahmad
Bhai jn Change the steering belt urgently then fill the steering pump oil at optimum level
Then reply after doing these simple thingsNai to ap sath hi Japanese steering pump dlwa lo
ان شاء اللّٰہ ، آواز نہیں آۓ گی
Radiator ko 90 percent with Normal Coolant k sath and bottle ko 50 percent coolant sey top up krei , bhai jnPhir check kr k btaye k radiator bottle sey intake krta hey ya level neechy krta???
The sound you are mentioning comes from the engine bay, not just below the steering wheel.
My Liana is bit of underpower. How exactly being an underpower car relates with the clutch plates? How someone knows that now it's time to replace the clutch plates? One of the mechanic tested a drive and said, "Your car need a new clutch plates bcs it is bit of underpower and doesn't accelerate when you press the pedal." I argued that Liana 1.3 is already under power. Should I replace the clutch plates?
i believe failing clutch is checked by another method and not merely decided by bad pick of car. clutch change is a big expensive labour intensive job in liana. be 100% sure before proceeding for it.
Yes thats upto the mark
