From morning till nowLight wont ON now.Next time jab ON hu gye then i will scan the car.Sorry for not mentioning whole scenerio.@dani_kk@SER_GTROne more thing.I find obd2 scanner online costs about 1000rs.Would it work with liana ?Its selling on daraz.pkWould u recomment to buy scanner or not?
It should be v1. 5 to work with liana...I own a ancel v1. 5 scanner elm327...Bought it for 2k. From rwp.
Would u post pic of ur scanner which u bought?PKR 393.67 13%OFF | 2018 Super Mini ELM327 Bluetooth V2.1 / V1.5 OBD2 Car Diagnostic Tool ELM 327 Bluetooth For Android/Symbian For OBDII Protocolhttps://s.click.aliexpress.com/e/bWW5OUxq
Mn nay ye dekha a aliexpress say
Have you tested it on Baleno? Does this scanner work with it too?
Haven't tried it.but it should work..In liana have body control module codes, engine, automatic transmission, abs,ac
it will NOT work on a Baleno.
@rcwaqas I guess Saboor73 has left this forum for good. If you wish to contact him you can do so by visiting https://forum.thegreatpakistan.com
Cheers
@abid110 @dani_kk For price of 393 ..worth it to tryWhat u say sir?
It will NOT work in baleno. You can try for dil ki tasalli
@abid110Some other issue also want to discuss.For last 6 months and soOften happened when i turned off the fan switch .Air still coming from vents but at speed of like 1.It happens like once in a blue moon.I checked car to 2 3 electrical mechanis and they said wiring and fuses r prefectly good.Any one know about this?
Give 393 to some poor.. Duayen degaaa apko
Yes waise ap saye huAcha @dani_kk kiya ap meray last walay maslay par kuch bta sakty hu?
Looks like a bad switch...
I just clean the fuses of motor relay and ac ...problem gone of fan ON.But the engine check light again ON for short trip and then when i came back home.its again OFF.Mechanic nay car qchw tera check ke and he didnt find any loose wire.Ap kiya kru?No error on obd.jab lagata obd scanner reset krta a ecu ku uskay baad light band.
Found code this timePo135 O2 sensor code.Last sensor 2 year he chala.Found kabli one costs me 2000 and 300rs dalwai with computer checkingI also have faulty window switch power400rs ka kabli wu be mil gya full.Mentioning here price just for people and memebers
@NiGhTShAdE sorry offtopic, i saw one of your posts where you bought civic 99 antenna from montgomery for 1100 of course ab is price pe nae milnaaa but can you tell me kahan se liya tha :((((( i need that antennaaaaaaaaapls pls pls contact me on whatsapp with your source of purchase 03218055888
Yaar bought it two times from there but ab shop yaad nai hai....it was very long time ago...It was not very hard to find, shop was on right side when you enter from petrol pump end of Montegomery road.
