After Repairadjusted
@racerali look my car bumper and headlights are not aligned properly what should I do?
and next problem is that this connector have wire broken I did some jugaar but I need to fix it properly. can you tell me the solution?
[ATTACH=CONFIG]1436535[/ATTACH]
@john0995i will tell you what to do after jummaThanks
ok bro
@john0995
1:-Fender needs slight outwards you can do this by remove under hood bolts2:-as mention in pic3:-under bumper need rotation 3 point line become stright
Bro can you kindly tell which screw or bolt fitted in side like in this pic pointedas mention in this pic which type of screw as in my civic there is bolt and after proper genuine inner fender fitting bolt fitting is impossible can not find in internet too:(
1:-slightly close make it normal2:-As mention in pic3:-Normal4:-under hood lose these two screws and push headlight up wards so it align with bonnet
bro you need to replace the grip
Bro why you remove the reflective beam (don"t know exact name)
this make straight beam and not make upcoming traffic blind like in Suzuki Bolan Mehran etc.
from where I can get this grip?
I'll post the pic of that screw
Thanks for the reply but can you kindly tell me from where or which item hold it
from sadder or chah sultan rawalpindi
this plastic thing is not present in both headlights
are you talking about the back of that screw?
3rd pic is suzuki bolan headlight me trying to tell you it is dangerous
