there are multiple retailers in Lhr/Islamabad etcdo check atec solutions FB page, they will guide you depending upon your locationhttps://web.facebook.com/ATECValvolineDistributorother than retailers, atec also inaugurated a company operated shop couple of days ago in lahore
No it will evaporate due to improper build
Good stuff, this brand is usually a cheaper alternative to material like shell tf0870 awd oil, or mazda blue atf etc.
For engine oils they are expensive, but they will sell nicely in Pakistan due to german language on the container.
Hey brother.I’ve 1.8 cvt 2019As per manual it says to change the oil near 100k km. but my mechanic and the dealer ship says to get it changed at 40k kmMy car is driven 44k km atmShould I get it changed? And what about the pan and filter? Get it opened and cleaned or no?
Kindly suggest fully synthetic 5w30 oil brands.
Many brands discussed here. Go though the thread.
Can we carry engine oil from Germany or usa to Pakistan on plane?
Hello Pakwheelers.I need someone to suggest me a good mobil oil with grade for my honda civic 1997 Vti.I have 1600cc vtec engine and is currently 277000km driven.I am using valvoline 20-50w. Should i use another one or is this okay?
From how long you being using 20w50? If there's no slug inside the engine switch to 5w30. And if it burns oil with 5w30 then settle with 10w40.
As i boought car recently i changed the oilI have driven 2000km on it
Then switch to 5w30 on next oil change.
Isnt the viscosity very low of 5.30w. The car is 277000km driven wouldnt it effect the engine ?
No it wouldn't. If something is wrong only then it will start burning it. Otherwise mileage doesn't matter.
Hey @Hassan1991. I am going to change my engine oil in the coming week i already told you that im using valvoline 20w-50. My engine oil is not burning oil. Also i have run 4000km on it. You said to switch to 5w-30 but i wanna get certain about it so my engine isnt affected. As summer is coming and the tempratures are high. Using 5w-30 is good for my car or not. Kindly suggest me a good solution.My mileage is 289000km. Secondly my fuel average has gone worse. Kindly suggest me possible solutions to improve my average. JazakAllah
If you are worried they try 10w40. Bad mileage can be due to thick oil.Moved you thread here.
I don't think such Liquids are allowed.
https://fb.watch/bEEELEEQEw/ <-- interesting link
Car mileage is 38k the previous owner use toyota simple genuine oil not semi synthetic or synthetic , after i bought the car i use toyota central motors karachi , i personally want to use synthetic for good fuel avg they use 5w 50 is that ok to use ? I want to run my car on synthetic the next service due on 40k
I bought brand new altis 1.6 in 2016. Using toyota non-synthetic petron 20w50 oil since beginning (as recommended by toyota). Mileage is now 75k. Still using same oil ... having no problems at all. I recommend to use the same. You wont get miracles in mileage using synthetic 5w20 etc
use 5w30 fully synthetic atleast, not beyond that
