can you provide mercedes benz recommendation to back it? Im telling you exactly what MB do when you roll in with your car for a lube service.
The old FSS cars will change the oil life cycle as you add oil and keep on driving on highway, when the same car is used in city where it has more acceleration cycles it will reduce the oil change interval, All those cars take 229.3 oils - if you use 229.5 then you dont follow the FSS and rely on the oil change sticker. (this is why FSS cars oil level sensors are extra expensive - they actually measure oil quality too)
with 229.5 oils you set it with service assyst and its loosely based on fuel used and the odometer read. - If a dealership uses a 229.3 oil in a 229.5 car it doesnt matter much except for it being slightly harsh on the AFR sensors, but most dont as 229.3 oils are a bit pricey than 229.5 oils.
