i have been tired of replacing lead acid batteries used with Local Made UPS, after every 9 months
during search for mazamizing batteries life i have found a device named Battery Equalizer
Battery equalizer is used for the lead-acid batteries which are connected in series to keep battery voltage balance.
When two or more in-series connected batteries are in charging/discharging/free status. The battery voltages maybe become different. One battery voltage is high and one is low.
The battery equalizer will equalize/balance the battery voltage when it detect there are 20mV between two batteries. It will shunt current from one battery (the higher voltage one) to the other battery (the lower voltage one). Until their battery voltage almost becomes same. This will improve battery’s performance and extent battery’s life time.
For example: If battery equalizer is be used for 24V, 36V 48V battery system:
1 piece for 24V system;
2 pieces for 36V system;
3 pieces for 48V system;
Technicial Data
Battery nominal voltage 2*12V
Optimizing current 0-5A
Quiescent current <3mA
Dimensions 70*70*27 mm
Protection Reverse polarity protection
Low Voltage Disconnect 10V
Installation
Please connect the battery equalizer to battery as follows: (Please check the pictures)
- Red cable: Battery A positive/+ pole
- Black cable: Battery B negative/- pole
- White cable: Battery A negative pole or Battery B positive pole. (The pole which connected Battery A and Battery B in series)
product costs 4900 rupees + 100 rupees for shipment from Lahore to Multan
further details can be seen at link below
Solar System Pakistan Private Limited.
