Dear Whiteangel,
CCA, CA, LOAD TESTING, STARTING APPLICATIONS:
Cold Cranking Amperes (CCA) is measure of amount of current your battery can deliver at 0 F for 30 second once both terminals of battery are shorted and voltage does not drop below 7.2 Volts for 12 Volts battery.
Some time battery comes with CA rating with is specified for 32 F. higher the CCA rating is typically used for starting applications but not referred to deep cycle batteries.
Never short your battery terminals as lot of heat is generated during this process and you may end up destroying your batteries but this is exactly what happens once you start your car and this is a typical how a load testing is performed.
AH RATING
Normal batteries available in market comes with AH (AMP HOUR) rating which means that 145 AH battery can deliver 7.2 Amperes for 20 hours before it would need serious charging again or 14.5 AMPS for 10 hours before it requires charging again. AH rating is expressed in number of amperes a battery can deliver for 20 hours which is calculated by dividing AH rating by 20.
DISCHARGING RATE
In order to get the best service from your batteries the batteries should not be discharge more than @ AH/10 which for 145AH battery is 145 AH/10 =14.5 Amperes. But it is ok to discharge a battery with AH rating divided by 6, 4 ,3 so this means that you can discharge your 145 AH battery @ 145/6= 24 AMPS , 145/4=36 AMPS, 145/3= 48 AMPS but don’t expect it to last for 4 hours. In case of UPS, I am unaware how much load you have inserted and number of batteries you are using in parallel or series but you can use Ampere meter to observer the load on your batteries during load shedding and if you see that the rate on each battery is more than try to add more batteries to your UPS as current divides in parallel.
CHARGING RATE
Once you are charging your batteries then right rate to charge a battery is you’re AH rating divided by 10. That for 145 AH battery the right charging rate should be 145/10=14.5 Amperes. Slower charging is good for batteries but you have to prepared before next load shedding. Anything above AH/10 is termed as fast charging which would damage your batteries in long run but you can do it for few times if your are monitoring the process and anything below would be termed as slow charging and I can guarantee that this would prolong the life of your battery.
Remember that your Air Conditioner consumed 8- 9 AMPS of current once the compressor is on so you can very well imagine how much power you are wasting once you are not taking care of your system.
1 YEAR IS VERY LESS TIME FOR BATTERIES TO LAST:
This is abnormal for batteries to last for a year, try flushing the batteries and adopt the same procedure I have told you in this thread and I hope you will realize that your batteries were not dead.
