@talhawaleed
Thanks brother for replying. I am cent percent sure that 285 volts is NOT the voltage of UPS. It is the voltage of WAPDA line. Reasons are given below:
1) The input and output is displayed clearly on the LCD display. And on the back of Homage UPS input is where we plug in WAPDA line and output is where the UPS wiring to home appliances is connected. Same is written in user's manual.
2) When there is load shedding, the input reads 0000 volts and output reads some value between 220-230 volts, which is obvious as during load shedding WAPDA line has no voltage.
3) If the problem is with UPS voltage then during load shedding it should also show high voltage but it always remain within 220-230 volts.
4) If 227 is WAPDA voltage, then why UPS is on "backup" mode? It should be on "line mode"
5) When I connect my room lights through UPS, they are of normal brightness, but when I connect my room's light directly to WAPDA (by bypassing UPS), they are extremely bright.
6) The bulbs in our home which are not on UPS fuses every week or so. TV and fridge burned once.
