You are right Taimoor bhai, Audyssey curve is pretty good actually. I also like the Harman curve minus the bass boost. Harman curve is very warm, to some its good, to some its too laid back, matter of personal preference. I remember when I had the JBL MS-8 (Harman curve) the setup sounded really good (apart from the boosted bass).
I recently tried the Alpine PXE-H650 (Audyssey curve) with the Scan-speak tweet and the JBL GTi midbass driver. Sounded great too. Also depends on the type of music and genre one listens to.
You are right, reflections are not good for any audio setup, specially in cars where the drivers and the reflective surfaces are in the near field and can not be avoided what ever we do. In car, we are not actually listening to the frequency response of the drivers, if we were getting the FR of the driver then there would be no need for eq. What we listen to in car environment is actually the "power response" which the sum of direct sound of the driver + the reflected sound.
There are 2 types of reflections in car environment 1. Reflections close to the driver 2. Reflections close to our ears.
1. Reflections close to the driver: Since the driver within its dispersion range is emitting the sound in a spherical pattern, these cant be avoided therefore EQing them is the solution.
2. Reflections close to our ears: Now these are the nasty ones and one should be worried about these reflections. What they do is, induce crosstalk. Meaning sound from the right side driver entering our left ear and vice versa. For example, reflections of the drivers from door glass windows. These sort of reflections gets worse when the driver is played beyond its dispersion range. When a driver begins to beam it does not spread the sound in all directions, it simply emits the sound like a beam in the forward direction. Also when a driver beams the angle of incidence = angle of reflections. These sort of reflections ruins the imaging, it also confuses the auto DSPs specially in TA and then we blame the DSP instead of improper install.
I tried to avoid 2. by directing the tweets at each other, but at an expense of off-axis, top end natural roll off. Will wait until the drivers break-in, after that will manually tune the setup and maybe move the tweets 30degreeoff-axis. Lets see how it goes
