salaam,
thank you for your reply ,
well its all about personl perference , i do agree that you have gone through all this trouble in terms of rotary , but my friend Ahad if you tune a rotary properly it will not give you any problems , yes a apexi power fc is important for tunning a any car , but thats were it does not stop, you need dyno and other special softwares to get it tunned , which i agree are not availible in Pakistan , the only dyno i can recall is in islamabad ,
and as far as flooding of the engine is concerend that my friend happens if you do not properly heat the engine at optimal level and imditly shut the engine is off , that is an issue with the rotary
ok , i did not got what you said , correct me i am wrong , as far as i could undersatnd , you installed 3mm apex seals and those seals blew up ?
that should not happen , it will will only happen if the boost is too much , or the oil lub is not right
and about the spark plugs Ahad you can easilly get the lead and trail spark plugs from here , the only things i had to order were the airfilter , fuel filter and brake pads ,
it was nice that you shared your experience with me ,
bye
