This is the last installment for the muffler study. In a brief recap, my study was to find a muffler solution for the FS racecar powered by a 600 cc yamaha r6 engine. To do so i needed to keep in mind the performance and the sound emitted (limited to 90dB). Therefore I selected a few mufflers from the market and manufactured 3 myself as stated above. The list of these mufflers is given below:
1) Orignal Yamaha R6 titanium muffler (resonant + absorptive)
2) JDM toyota corolla silencer (resonant)
3) Aftermarket Muffler - HKS first copy (absorptive)
4) Self Made 75mm diameter and 400mm length
5) Self Made 100mm diameter and 500mm adjustable length (500-400-300)
6) Self Made 125mm diameter and 400mm length
The three self made mufflers allowed me to analyze the impact of diameter and length both (using the absorptive principle, discussed above). The self made mufflers allowed me 3 configurations for length (300-400-500mm) and three configurations for the diameter (75-100-125mm). Further i also had 3 other exhausts. Therefore in total i had 3*3+3=12 experimental configurations.
In the experiment I had to determine the backpressure cause by the mufflers and the level of sound attenuated by each. Given below are pictures of the experimental setup and procedure (you can also see the variable length muffler in one of the pictures).
Results & Conclusion:
1) The R6 titanium muffler had the greatest sound attenuation and the second highest backpressure. The back pressure was due to the fact that it uses the resonance principle and the attenuation was greatest as it was designed for this engine.
2) The JDM toyota silencer has the second greatest sound attenuation and the highest backpressure.
3) The Aftermarket HKS first copy had the lowest backpressure and the lowest sound attenuation.
4) The self made exhausts had the second lowest back pressure and low levels of sound attenuation, however all three of them in the full length still emitted sound which was within the acceptable limits. However an important discovery was that with increasing length and diameter the sound attenuated was greater. Therefore the level of sound attenuated was directly proportional to increasing both the diameter and length.
Therefore the theory was proved. The greater the sound attenuation, the greater the back-pressure. Also another important revelation from the experiment was that at low engine frequency (low RPM) the resonance principle worked better however at high frequency (high RPM) the absorptive principle worked better.
Hope you guys enjoy and learn from my experiment. Do comment and ask any questions possible!
Regards,
Ebad
