Dual Action DA Polisher
880Watt Dual Action Polisher MS-DA900 Rs13750/-
Unique Features:
Fast, Powerful Effective, Safe and Easy-to-Use
Swirl-free, Professional Results with No Risk
Easily Removes Swirl Marks and Scratches, and Improves Paint Gloss
Ideal for Applying Polishes, glazes, sealants and Waxes, and Safe on All Paint Types
Variable Speed Dial, On/Off Sliding Safety Switch
Ergonomic Design and Comfortable Soft-Touch Head Cover
Auto Shut-off Carbon Brushes, Low Noise and Low Vibration
Sealed 100% Ball-Bearing Construction Provides Longer Life
Specifications:
Rated Voltage: 110V - 240V AC Orbit Diameter Size: 8mm ( 5/16" )
Frequency: 60Hz / 50Hz Thread Size: 5/16"-24
Rated Current: 7.5Amp.
Velcro Backing Plate Size: 125 ( 5" )
Rated Power: 880W
Variable Speed: 2, 500 - 6, 800 OPM
Net Weight: 2.3kgs (4.8Lbs)
Power Cord:4.0 meters Heavy-duty Cable.
Accessory:PU Velcro Backing Plate,D Handle,Wrench,Carbon Brush.Manual
6-Speed Settings: Recommended speeds are as follows:
1:2500 OPM - 3200OPM Waxing & Buffing
2:3900 OPM - 4900OPM Polishing & Cleaning
3:5500 OPM - 6800OPM Removing paint defects and Swirls
Dual Action Polisher Help You Make Vehicles Clean And Shine.
Dual Action Polishers Help You Make Car Detailing Safer and Easier
