Meguiars Smooth Surface Clay Kit
Creates a smooth-as-glass surface!
The Meguiars Smooth Surface Clay Kit is a complete detailing clay kit from one of the oldest names in car care. Everything you need to clay your vehicle is right there in the box, even a high quality microfiber towel. Meguiars Smooth Surface Clay Kit rids your vehicle of contamination so the best possible paint can shine through.
Clay works by removing contaminants that are embedded in the paint finish. They create tiny bumps that interfere with the bonding of the wax and create an uneven reflection. These contaminants include rail dust, industrial fallout, overspray, and brake dust. You might not be able to see them but you can certainly feel them if you lightly rub your fingers over the paint surface. Give it a try. Feel the grit? It?s time to clay.
Meguiars clay is nonabrasive and safe on paint, metal and glass. As you glide it across the surface, whatever is stuck to the paint will stick to the clay. The included Meguiars Quik Detailer makes an excellent clay lubricant. It prevents the dirt on the clay from scratching the vehicle as you continue rubbing. Keep an eye on the condition of the clay; if it is particularly dirty, reshape the clay and use a clean portion. After you?ve clayed each section, wipe off the residue with the Supreme Shine Towel.
Clay does remove wax so be sure to follow up with the your favorite carnauba wax.
Here?s what you get in the Meguiars Smooth Surface Clay Kit:
Two 80 gram Meguiars Clay Bars
Each clay bar is 80 grams. This is a nonabrasive clay that works on any paint finish, especially clear coats. Each bar is individually wrapped and packaged in a reusable plastic case. When you store your clay, mist it with Quik Detailer to keep it fresh.
16 oz. Meguiars Quik Detailer
Meguiars Quik Detailer is full of lubricants that provide a slick barrier between the clay and the paint surface. The clay glides easily across the wet surface without scratching. Even delicate clear coat finishes are safe as long as the paint is well-lubricated. Plus, Quik Detailer can be used to remove any clay residue and it leaves the paint smooth and glossy.
16 x 24 Supreme Shine Microfiber Towel
The Supreme Shine Microfiber Towel is made with a deep, dual-sided nap that wipes away wax while rendering a smooth, mirror-like shine. The fabric is pre-washed prior to being hemmed to give it maximum absorbency right out of the package. The thirsty fibers can absorb three times more water as a terry cloth towel and microfiber is softer, too!
Meguiars Smooth Surface Clay Kit is a simple, all-in-one package for the clay novice or a detailing pro! Detailed instructions are included on the box.
An all-over claying should be performed at least twice a year on a daily driver. Even if you can?t see the contamination, it?s there. Meguiars Smooth Surface Clay Kit gives you the tools you need to deep clean and protect your vehicle.
The Smooth Surface Clay Kit includes:
2 Meguiars Clay Bars
16 oz. Quik Detailer
16 x 24 inch Supreme Shine Microfiber Towel
