here sharing you different kind of car polishers :)<o:p></o:p>
Orbital buffer<o:p></o:p>
The motors and drive units on these two types of polisher's oscillate in an eccentric circular motion. Usually works on fix lower speed, light weight, easy to use, usually with dual handles. Have single jiggle movement rather than spin, good for applying car waxes, glazes ( non abrasive products only ) good for applying product deep to paint works with less effort, in less time, don?t have paint cutting ability, a new user can operate without any harm of damaging paint , this buffer don?t generate heat so cant burn paint , usualy if apply too much pressure on this the oscillating action on polishing pad will stop <o:p></o:p>
Its not a professional level product<o:p></o:p>
Dual-Action polisher<o:p></o:p>
By the name combines 2 actions, one the rotating the pad and same time also oscillation of the spindle . in simple words its action is like action of earth which not only spins itself but also orbits or oscillates arround the sun.<o:p></o:p>
This unique action prevents the creation of holograms, paint burns, this is good polishing machine and getting popular in detailing world , <o:p></o:p>
Run on variable speed usualy 1800 to 6800 rpm so having ability to correct minor paint imperfections like light scratches or swirls removing , it wont have ability for correcting serious imperfactions
<o:p></o:p>
Due to its unique action its good for cleaning paint,compounding, polishing, glazing ,wax applications, good for removing oxcidation and helps to apply much thinner applications of wax and polishes so also easy to take them off and create more uniform and higher gloss finish, can use different pads as per product and requirments.<o:p></o:p>
Rotary polisher <o:p></o:p>
Rotary buffers are drastically different in the way they work compared to Dual-action polishers and Orbital buffers.
The drive unit used in a rotary buffer is referred to as a direct drive, This results in a powerful rotating motion. This rotating motion is typically clockwise.<o:p></o:p>
Due to its direct driving the rotation its creat heat so easy to correct / remove serious imperfactions faster than da polishers<o:p></o:p>
<o:p></o:p>
<o:p></o:p>
Remember, using a rotary buffer successfully requires both skill and experience. If you use a rotary buffer and are not skilled in its use, you can easily apply too much pressure to the paint and burn right through it and requiring a new paint job<o:p></o:p>
This is best machine for paint correction faster and deeper however it?s a professional level machine and inappropriate use can harm/burn the paint <o:p></o:p>
<o:p></o:p>
Good for compounding, poloshing, removing orange peel, deep secratches<o:p></o:p>
<o:p>
here are pics
first pic orbital polisher
second pic dual action polisher
third pic rotary polisher </o:p>
