No idea brother. After reading this thread, I tried myself and it fixed my problem. All members give a try because jerks at low rpm is not current related.
Indeed this is not the issue of weak current. It has actually to do with excessive vacuum pressure that builds up in tank and then car start taking jerks. Drive your car in hot weather and let us know if the problem was resolved or still there.
Bro waiting for your comments after drive in hot weather..
Sent from my SM-G530H using PW Forums mobile app
I tested from every aspect. Also tested driving after idling for 5 minutes with AC on. Mostly i drive within city at low speed with AC on. Running smooth. Before changing pipes i had to keep heavy foot on accelerator. No issues so far, no change in mileage.
Can you please post pic
The weather is not so hot in Lahore these days. You will get the real idea when you drive it in noon heat of up to 45 C.
I never drive without AC. Till now i have covered 1200km after replacing pipes. I'll update if problem comes again.
This is good. Let us know which pipes did they change.
Waiting for the details of pipe changed
The title of this thread is
Sent from my iPhone 6s using PW Forums
These three pipes.
These are two.. did you find any crack or damage in old pipes??
@turbo_chargeI forgot to mention that i changed the pipe locations.Still no issues, problem is solved now.Pictures attached for better explanation. Do let me know if this solves your problem.
My friend is complaining steering wheel vibrating on his 2016 mehran at 100km/h? Is it balancing issue or its like this in all of them?
Very good... did you do it your self or some mechanic suggest you to do this..
Wheel balancing problem..
hi to all......meri mehran jerk tu maar rahi hai..lakin fuel average 12 se uper jati hi nhi
Sent from my HUAWEI VNS-L21 using PW Forums mobile app
Meri fuel avg theek hai.. 15 sy 18 Tak.. depend on speed and a.c. use
Drive with light foot.
My new Mehran has the same jerking issue when AC is turned on and the car is running in 1st or 2nd gear
