I have not check this from Suzuki.. but I remember if you go local market they cost up to 25k for a.c.... Suzuki must charge high
Sent from my SM-G530H using PW Forums mobile app
Sgo ultimate is api sm sgo and very bad oil for mehran use Sgo premium in mehran
Sgo premium is best for mehran
I surely get confused bw ultimate and premium.. by in always buy sgo.. golden brown box
Agreed
Thank you all for quick response! i was expecting Havoline or Zic response from members! turns out to be something else! In Sha Allah I will get it change today SGO premium. I hope it keeps the engine temperature to optimum while AC is on!
You, 'll get much better result.. my one mehran is driven 120k and one is 9k.. both are in sgo oils
Confirm from Suzuki 3s dealers. 1) sgo ultimate for 5000 km2) sgo premium 2500 km
They pore ultimate in mehran and always do that in mine both cars... no issue and good average..
sgo ultimate golden box should not be used in a mehran. it is api sm and contains low levels of zddp. mehran requires zddp in abundance. if not provided, the rocker cams will wear out. one should try using an api sj or earlier in a mehran. at max one can use is api sL. no later than that. so sgo premium works for about 3000 kms and is recommended for a mehran. screw what the dealership says. @tintin1 can guide better
But point is I did no having any issue with any of my mehran.. one car by driven 120k one new efi... every 3s dealer use to pore same oil
consider urself lucky if all is going good. senior member @xulfiqar has quoted certain cam failures due the the usage of high spec oil.
Can you please share links of xulfiqar posts
there are lots of them. try google zddp and xulfiqar. u'll get all his discussions
Thanks
Hi akashamanat66. Did you find any solution to this ac compressor problem. I am facing the same issue with my mehran.
2500km is too less..i confirmed from 3s and they endorsed for 5k km for premium...
Sent from my QMobile Z10 using PW Forums mobile app
Do you face the needle jumping over 50% temperature on ac? Same is my case..
Its not true.. please reconfirm
Nahi yaar...2500 is too too low...atleast 4k km..
3000 kms is fine keeping in mind the api sg grade
