hey experts, need a bit of advice
my mehran 2006 VXR (80k) had play in the gears and and occasionally it was difficult to engage 1st gear. like am stopping on a signal and when want to engage the first gear i could not, so i first engaged 3rd gear then neutral and then again 1st. sometimes this practice was needed 2/3 times...so when i visited Suzuki 3S for 80k checkup i also had them check this. they replaced a "cross -t" it was a white plastic t, after that the play is gone and it is easier to engage gears (i should also mention that gear oil was changed @ 79k recently). but still sometimes i still find it difficult to engage 1st gear. though the problem is improved but not still fully resolved. what should be checked for this, it is the clutch plate wear that is causing this or some thing else? kindly guide me regarding this...
one other little thing, when i start the car especially in the morning, it has a little vibration due to cold and the silencer generates some noise. agar me silencer ko pakar *** to awaz khatam hojati he and that made me realize it is related to silencer, so i checked it a lil bit more and i observed if i press the second last rubber bush from the rear the sound stopped. I talked about this with Suzuki guy, he checked all the bushes and said that they are fine and in proper condition, doesn't need replacement, and that this one is fitted like the way it is. So i guessed maybe ye bas jaan churana chah raha he kaam se, so should I let some silencer guy look at this. this sound is no much and is very faint from inside the car, but i really hate this noise and want to get rid of it, so kindly advice for this too
