no price idea of rear Defogger used hi milna hai bro
Thanks EK
CTRL + Q to Enable/Disable GoPhoto.it
Thank you...Should i also go for petrol tank change and how much will it cost in total???
y would you do that? if tank is Effed up then u can go for a change i think including tank 4 to 5k expencies and oem fuel pump is for 2200 and china wala is for 500 to 1200
else clean the tank and re attach it btw did tank got any petrol in it since 2 years if there is then u mght need to drain it
Thankyou for prompt reply....
Car temp needle stays below "C" in morning time all the way and in rush or noon time its in middle or below middle depends, fan is auto. is it normal for mehran? i do hav xli which's needle stays at middle all time. car in question is 2006 mehran.
is Fan Auto or direct and if thermostate valve is installed then it should remain in middle after getting to normal running tempand i think thermostate isn't installed or not properly working but in rush it stays at middle i think its normal
Yes fan is auto, never exceeded from middle, but at morning or in cool weather its below "C" mark, no matter how much u drive its below C. Isnt it harm for engine runing below normal temp???
I have a issue in my Mehran 2013 Euro II . The horn of car sound very odd when car got some heat. Like i stuck in some traffic then it does not work correctly. But when car got some speed it works fine.What should i do ?
Check your horns wiring connections
yara sa owem nu does it have thermostate valve? btw sir call me or sms me and knowing ur route i think thermostate paky nistha as it should not loose temp on driving on open roa
Nu snga ba pata lage che TV pake neshta? Ok teek da saba ba cal okam us late da, thanks
Yara do experiments Let ur car idle in morning till temp reaches mid thenn drive it if on highway it drops to c then tv nishts if it stays in middle then it is
Sent from my Lenovo A3000-H using PW Forums mobile app
^^got it, therez no TV in my mehran. is it okay to run like that or should i go for TV.
when i press clutch and release while still in neutral, car moves little back and forth and i also hear voices of some rotating metal while pressing clutch... any thoughts?
Sent from Mars using Telegraph
Staso marzi da asy kha khabara da kho A wem che garay taso awal shar sam temp ta kai awo boya raawan shay but install it as heater um kar na kai che tv navi
Sent from my A10 using PW Forums mobile app
There could be something wrong with gear selecter mechanism and if u feel gears are not engaged on spot then change gear kit 50 price hai sir And on metal sounds clutch place and pressure plate could be at fault even the bearing check that from a reliable guy but never let him take apart gearbox
In the morning? If yes then its because of the viscosity of the gear oil, thickness.It makes the car drag a bit ,cold drag maybe,xulfiqar knows about it.Use Zic FF gearoil.
Sent from my HTC One X+ using Tapatalk
In my case clutch plate and pressure plate were done but oils also depending on quality
