itna dimagh na lagao go for 8mm plug wires ultima or any other brand
Sent from my GT-I9300 using Tapatalk
thank u ekdrifter for reply. i go for ultima wires currently this brand wires are not available. one shopkeeper shown the NGK brand cable and Truepart. which brand is best performance wise on CNG too???
oem ngk cost a fortune but they are not good in terms of performance believe me i took out ngk oem wires which come from factory in alto and cost4000rs i took them off and got those 8mm installed for 800rs
Bro how can I lower my mehran from behind? Removing pattays of kamani could be dangerous is there anyother way?
Go to the leaf spring(kamani) mechanic and ask him to lower the car....he will adjust the bend in them to lower the height of the car...
Aoa my car is giving pungent smell from exhaust on petrol. Average is good i-e 13-14 km/l. What could be the problem ignition timing is ok and point is also good great pick on both cng and petrol
air fuel mixture is too rich get the car tuned properly. Fuel filter should also be changed after every 10000 km get the one made by leppon or suzuki!
But the consumption of petrol is good
If the ait fuel ratio is rich it won't necessarily mean that mileage will be bad but its bad for the engine's health
Sorry about that. I don't know what happened. All pictures were supposed to be in a single post. Anyway changed brake pads and re=greased CV Joints. Brake pad was stuck inside the caliper and see the bent. Thankfully it was working but still I don't know how did it happened.
