dunlop 145/70/12 14000 for 4, islamabad, recently bought
1st i loss A & b, then tite the A till car come in complete sound n perfect sound, then i tite the B till stable on that, as car start vibrate i stop it, is this correct way to tune car?????
do they offer any cash back for your old ones ans is fitting and balancing free
B is the idle mixture screw
Sorry for being naive but where in the engine hub are these screws located?
going to change the Gear oil which one is recommended out of ZIC ? or PSO gear oil?
which will be for mehran , quantity
gear oil can be change separately or is it good when to change the engine oil so change with it along?
No it is not...Tight A so that it is JUST in contact with the butterfly assembly, as soon as it just comes in contact stop tightning....make sure you DONT press it to the level where butterly assembly get pressed....the purpose of this screw is just to make sure then butterfly does not put any force on wall od carbeurator when it is fully closed rather it should be stopped with this screw.....Now adjust B....Tight it till the car vibrates then slowly open it...when car becomes stable just open quarter turn more....and you are good....
zic ff
bro very little gear oil was leaking of my mehran i went to mechanic he drained gear oil and open some pan type thing and replaced the rubber seal and gear oil leakage stopped but gears got bit hard what can be reason and solution and clutch was replaced 7000km before
may be wrong grade oil or clutch adjustment is out
bro after replacing my car dholki in middle as said by silencer wala that it is leaking he charge me 2000 for it and still now silencer has ptakh ptakh sounds and some sort of leaking.
i'm using shell helix hx5. it is good. can I use 5w30 or 5w40?
using zic ff but i think i will check for clutch adjustment
it is a good engine oil i mostly use zic A+ 5w 20 in alto
vacuum pipes from and to the carburetor and distributor of mehran
i show the distributor picture, pls show the carburetor picture.
which tyres would make my mehran a bit comfy
Hey man should I use it in my cultus too?
hankook h706 yokohams both are good and profile should be 155 70 12 max
which model cultus u have if it is old then u must check engine condition if it is in good condition get ZIC A 10w 40
Aray bhai apko bataya to tha kisi zamany me Anyway its vxr 2007 carby and engine is good but clutch plate is 6/10. Currently using shell 20w50.
