I bought a mehran 2007 and it axle have some "khar phar" sound I want to replace it and every one is suggesting that I should go for chinese axle as some chinese axle are better than OEM axle is it true if yes plz recommad a good chinese brand axle
I would sincerely suggest you to get the original or kabli one because I once got Chinese and the are not reliable.
then change point and clean the self
LZNFones i used are goood
clutch plate and pressure plate change them asap
@jazibdon fan is direct... you are right... some mechanic told me to direct the fan so it will keep ur car cool.. and when temp of car is low it would consume less fuel.. he suggested me to direct the fan specially in summer..
Do you have the contact no this person who is selling the meterz??
how much it will cost
Well I have studied about fuel combustion and it says that a cold engine consumes more patrol where as lpg is more efficient in cold temps
1900 a pair 1 year warranty
This not correct...car should run at optimun temperature...colder engines are more prone to frictional damages....Infact thermodynamically higher the temperature, more efficient would be the engine but temperature cannot be increased beyond metallurgical limits of engine block so cooling systems are introduced to control temp....
complete inner/outter????
just the goday sides walay outerinner kabuli milen ge cross and cross kuppa
its cdi, n how to clean self, or 2 din se ak or masla hai, diky par aysy start hoti hai jasy petrol cng mix ho jay to karti hai, power nai pakrti 2-3 mint bad power pakertti hai, gari 2 maheny se petrol par hao no cng in it
buy kabli
kabli one are usually repaired
no not repaired chori ki gariyon se utary hoty hen warranty b hoti hai, i have very good experience with kabli axles.
self electrition clean kare gacheck timing kuch lanja hoga petrol pe advance nahi honi chye
So what would u suggest... fan of radiator should be at automatic mode or at direct mode..??
Automatic
