going to metro
and buying this one
[TABLE="width: 100%"]
<tbody>[TR]
[TD="class: arial14bold"] PYROCOOL 500[/TD]
[/TR]
[TR]
[TD][TABLE="width: 100%, align: center"]
<tbody>[TR="bgcolor: E3E3E3"]
[TD="width: 24%"]
[/TD]
[TD="width: 76%, bgcolor: E3E3E3"][/TD]
[/TR]
</tbody>[/TABLE]
[/TD]
[/TR]
</tbody>[/TABLE]
[TABLE="width: 95%, align: center"]
<tbody>[TR]
Ready to use Coolant, Anti-Rust, Anti-Freeze
[/TD]
[/TR]
[TR]
[TD="class: arial12normal"] [/TD]
[/TR]
[TR]
[TD="class: arial12normal"]PYROCOOL 500 is a specially formulated long life engine coolant. PYROCOOL 500 meets or exceeds the ASTM D3306 and D4985 specifications for ethylene glycol based engine coolants. It also meets the General Motors, U.S.A., specifications GM 6043-M. PYROCOOL 500 protects the cooling system from liquid boil-over and works as an exceptional coolant. In freezing zones where the temperature is below 0oC, PYROCOOL 500 works as an outstanding antifreeze and protects the cooling system from the damage of liquid freezing up to –36 0C.Due to high performance corrosion inhibitors present in it, PYROCOOL 500 also works as a super anti-rust. It protects the cooling system metals including aluminium and brass from rusting and corrosion. PYROCOOL 500 prevents the formation of scale or sludge in the cooling system since advanced sludge conditioners and scale inhibitors are incorporated in it. Ready to use PYROCOOL 500 is formulated in deionised water.
[/TD]
[/TR]
</tbody>[/TABLE]
