Just made a transition from Sportage to MG HS - I have to admit the comfort and ride quality is better.
Although I believe thereās a learning curve involved and you have to manage expectations as itās not as responsive as naturally aspirated engine, Iām also noticing a few sounds / clicks not sure if this is normal or needs maintenance - servicing pls guide.
When putting the gear into reverse if the road is level / straight - the movement is smooth , but if thereās an incline or you have to reverse upwards to a car porch the car makes a clunk sound esp from the driver side of tire/engine and then reverses up - anyone else faced this issue ? Is it normal or a faulty drive shaft?
