The ADO15 used a conventional BMC A-Series four-cylinder water-cooled engine,[6] but departed from tradition by having it mounted transversely, placing the engine oil lubricated, four-speed transmission in the sump, and by employing front-wheel drive. Almost all small front-wheel-drive cars developed since the 1970s have used a similar configuration. The radiator was mounted at the left side of the car so that the engine-mounted fan could be retained, but with reversed pitch so it blew air into the natural low pressure area under the front wing. This location saved precious vehicle length, but had the disadvantage of feeding the radiator with air that had been heated by passing over the engine.
The suspension system, designed by Alex Moulton at Moulton Developments Limited, used compact rubber cones instead of conventional springs β this led to a rather raw and bumpy ride, but this rigidity, together with the wheels being pushed out to the corners of the car, gave the car its famous go kart-like handling. It was initially planned to use an interconnected fluid system, similar to the one which Issigonis and Moulton were working on in the mid-1950s at Alvis, but the short development time of the car meant this would not be ready in time for the launch. The system intended for the Mini was further developed to become the hydrolastic system and was first used on the Austin 1100 (launched in 1962). Ten-inch wheels were specified, so new tyres needed to be developed β with the initial contract going to Dunlop.
The car was designed with sliding windows in the doors, thus allowing for storage pockets to be fitted in the space where a winding window mechanism would have been. Issigonis is said to have sized the resulting storage bins to take a bottle of his favourite Gordon's Gin. The boot lid was designed with the hinges at the bottom so that the car could be driven with it open to increase luggage space. On early cars the number plate was hinged so it dropped down to remain visible when the boot lid was open.
To keep manual labour costs low, the car was designed with quirky welded seams that are visible on the outside of the car running down the A and C pillars and between the body and the floor pan. To further simplify construction, the car had external door and boot hinges.
All of these novel and elegant technical innovations resulted in a car with minimum overall dimensions yet maximised space for passengers and luggage.
The production model differed from the original prototype by the addition of front and rear subframes to the unibody to take the suspension loads, and by the engine being mounted with the carburettor at the back rather than at the front. This allowed an extra reduction gear to be placed between engine and transmission to reduce loads on the gearbox and prevent the rapid wear on the synchromesh which had happened on early prototypes. As a side benefit, mounting the carburettor at the rear helped to reduce carburettor icing, but did expose the distributor to water coming in through the grille. The engine size was reduced from 948 to 848 cc, which reduced the top speed from an unprecedented 90 mph (145 km/h) to a more manageable (for the time) 72 mph (116 km/h) β a decision that was reversed in 1967.
Despite its utilitarian origins, the classic Mini shape had become so iconic that by the 1990s Rover Group, the heirs to BMC, were able to register its design as a trade mark in its own right.
Cutout mini
