Looks great.
Hi guys need help mira fuel average is declined badly let mention my car details i am using 5w30 Fully synthetic total oil also have original air filter cost 2600 plugs are fine tyre pressure is 30-32 i drive on light foot phele aram se 20-22kmpl kari the magar last 1.5 month se 11-13kmpl kari hay Ac ki power bhe thori kam lagri hay mjy acceleration perfect hay kuch arse phele mene ghalti se local air filter lagwaliya tha magar 40km k bad change karwa k original lagwa hay koi guide karay ga k kia issue ho sakta hay i use mix petrol 30% Hioctane 70% regular please help.
sir g garmi bari hue ha, which city are you from?meri b move ki average full kharab hue ha aaj kal because of garmi and AC use
i am from karachi Ac tu bilkul he mar gaya hay khabi sahe cooling karta khabi bilkul he kam karta hay jab japan se ae the mene full tank bharwa kar khali kiya tha 824 kilometer car chali the total then band hogae last drop tak check kara tha average 27 tha with ac month Feb
How much it cost you without custom and how much will be the custom ?
Need Mira E:S original Spark Plugs !!!
mostly i have to travel from islamabad to lahore etc (long tour) is that 660cc engine capable of going that long with 4 person on a/c ?
some people say that we can not change miraβs battery with other batteries some features dont work like eco idling
Check your AC condensers. It may be chocked. Get it clean from service station who have steam wash facility.
You cant find same/orignal plugs as mentioned in manual but compatible Irradium plugs are available in market in NGK & DENSO.Just be careful while buying that same heat rage should be matched.
Yes, Mira is capable of these long tours. I recently visited Isb from Bahawalpur and back with 4 Adults, a kid and luggage.No issue at all. My friend frequently visit Swat from Peshawar without any issue.
You can change it. Just be careful to match Amprs. It should be minimum 50
Assalam o alaykum Guys,
I have just purchased Mira ES 2 weeks before. But one problem I observe that the ground clearance is too low. When 2-3 persons are sitting behind it hit speed breakers.Anyone else facing the same problem.??Please advise a good solution. Btw I am planning to add spacer or change spring coils. But I am worried if it will suffer car performance.
I would highly recommend you buy small hybrid like Toyota Aqua for that in long run .. that will save you a lot if you are frequent long route traveller . 660cc will do and wont cause major issue but its not built for frequent long highway traveling with full capacity
Get spacers if u r from Karachi go to RK AUTOSPersonally I feel original spring coils should not be replaced
I did some study.By adding spacers it will lift up vehicle from behind which looks a bit abnormal and will also effect drive at high speed.I have replaced spring coil with another of same outer diameter and free length but a bit thicker coil material (wire diameter). It has high Stiffness and stronger than the original one of Mira.After replacement I have checked the performance on several speed breakers and bumps.The result is excellent.Problem solved.
Kitne ke lagay?And spacers agar aap kisi aqal mand banday se lagwaein gay tou wo peechay 1.25 inch aur aagay 1 inch ke lagae ga Jo bilkul bhi abnormal nahi lagtay
I am extremely sorry to all those who sent me messages and I couldn't reply. I was not using pakwheels since a long time but I will reply to your messages from now Insha Allah.
Bro can u tell me the average price of Mira and subaru pleo and toyota pixis????
I think Mira XSA package with 4.5 grade is costing around 12.5 -13.5lac rest u can calculate for GSA and LSA package
