since written data is not available the quantities i can remember off the top of m head are
engine oil less than 4 litres, around 3.25
transfer case oil 1 litre
rear differential oil 1.2 litres maybe but definitely more than a litre
front differential 1 litre
coolant 4.25 litre probably
ATF 2. something litre if you only drain from the nut, around 5-6litre max if you remove the pan
power steering fluid capacity i dont know
also forgot to mention that you should change brake oil as well, bleed it completely, its good to do it every two years, DOT 4 brake fluid is recommended on the bottle cap but you can use DOT 3 as well, i used mobil 1 dot 4 but any DOT 4 or 3 will do from a reputable brand and sealed container, you'll need little less than litre for a complete flush.
all these capacities aren't very accurate and should be for reference when you are buying fluid, not when you are filling the fluid in the car, so make sure to read dipstick, fill port etc correctly and not over or under fill.
