@amjadch
Thank you for inviting me Sir! The car is bone stock except for:
Extra sound-deadening material under the floor. It's been put in from the fire wall to the rear door. reduces road noise quite a bit and mechanical noise very slightly.
100/80 W Koito Bulbs. They give a much wider and brighter pattern. A very good investment. It will not overload the electrical circuit.
Some spare radiator hoses in the boot. It has once happened to blow at the most inopportune moment.
Tow rope and extended toolkit. (For emergencies)
A bunch of scratches and small dents, each telling a little story of it's own
(Plus, a 4WD should never be pristine, as it's supposed to go into mud and on broken paths)
I re-upholstered the rear bench (myself in one afternoon) for more comfort with thicker foam.
120 AH Battery. Original was 65. Each time we change a battery, we put in a bigger one... No battery lasts longer than 2-3 years. Gone through 6-7...
Machined Nylon front damper bushes. My brother had them made on a lathe when we couldn't find the originals...
I lined the rear reflectors with Aluminium foil (the shiny side) to increase brightness of the tail lamps. They had become dull after so many years. Brake, Indicator and Reverse lamps. The only problem is that the lenses heat up a lot more than original...
The above or not so much "mods" as "Jugarrhh" If any one has other such small tidbits to share, it'll be cool. If not, there's always the POCUK website...
Cheers!
Sami
