@ishtiaq bro need your help....
Couple of months ago my plate of irfp150M got burnt and had to replace with irfp150N....couple of days ago my ups was ticking start/stop charging like 2 seconds of charging then 5 seconds stop then again 2 seconds charging and so on...
Today morning it didn't converted to ups when light went off**.... Checked and found 2 out of 5 the transistors were burnt (IRFP150N) ..on 1 plate. So removed them removed 5th transistor from second plate (5 on both sides) and soldered on first plate making 4-4 on both sides..
Then fitted back everything and connected to battery. It is giving output as tested by plugging mobile charger but its too much noisy now and also even on/off button is off it still runs and led show no status...
Please help what could be wrong? Some other transistor is also faulty or some issue with kit now???
Attached is the pic of original plate... new electircian used resistors on these points instead of direct connection as in this pic.... what is the difference? what is the purpose of the 2 wires going to kit from these plates..?
Ups is in open state so urgent help will be highly appreciated..
Thanks.*
