The factory rubber brake lines swell/expand during braking, whereas braided metal brake lines can't expand under pressure, so the pressure that would otherwise gets reduced during the expansion of the factory rubber brake hoses goes straight to the brake calipers instead, resulting in a more responsive and more predictable brake set-up
I added another item to my TRD collection this weekend by installing a TRD quick shifter. It was specifically designed to fit the AE101 series 5-speed Corollas and was discontinued quite a while ago, but thankfully I managed to get my hands on one last week.
The installation was relatively straight forward as it's a direct replacement for the factory shift lever, and I was finally able to use the OEM leather shift boot I've had sitting here for a while which came on the 6-speed models, as previously it would pop right out of the console every time I changed into 2nd, 4th or reverse as the factory throw was too long.
Gear changes are now much quicker due to the reduced throw and the actual feel of the shifter is a lot better. Previously it would "slop" into gear, but now you can actually feel the gears engage. Admittedly it takes a little bit more effort to change gears but in my opinion it makes shifting feel more satisfying. The actual height of the lever is about the same as stock and it compliments the TRD leather shift knob I've been rocking for a while
