Bro If Its 1999 Model Power Plus Than Its Really Got Some Power ...... No Need Of Any Engine Alterations But If You Want To Do So Than Plzz Lemme Know I will update you that what to do with engine alterations , coz kisii b aisay waisay mechanic se engine khulwao *** to woh kharab kr day ga engine ........ My Advise to u is to Change the silencer or so called exhaust with original one , remove the head light and put the original one .... rest is ok , BTW Me too is A Proud Owner Of "POWER PLUS"
Now Comes To The H.I.D if you are using H.I.D with the stock battery than change the battery with 12 volt 7amp or 9amp battery cost u around 1000rs . And If You Are Using A Single Tube Than Change It With Double point tube low = Halogen , High Beam = H.I.D ....... Coz Tha Blaster Needs A Power Plant Of Current Its Not For Regular Use On Bikes .
