Tom's Fuel Map Controller is a tool for self-adjustment of the fuel,
It may correspond to the naturally aspirated Toyota vehicles, as long as connected to Air-Flow can be
Adjusting the fuel supply valve 10 of the adjustment button can be modified with its own engine-fat
Gengshuang swing. ......
FUEL MAP CONTROLLER (FMC) is a use of the Air Flow Sensor air flow to control smoking intervention in the supply of computer equipment, and then adjusted using a controller. The benefits of FMC is to use the knob on the controller can adjust the amount of fuel, vehicle owners need to save oil-powered or can be arbitrary, and the controller extremely small, on the train at any location convenient.
In fact, FMC is somewhat similar to the previous fuel devices, but in the past the need for additional devices in the computer connected to the wire and need skilled technicians can install. TOM'S FMC but it is much easier, as all equipment connected to a plug just one, no need to cut the road connecting the computer line, as long as the Air Flow Sensor wire plug connected to TOM'S FMC, and then extend the line through the firewall split into the inside to complete the installation.
Remember leaner is meaner.
