FAW X-PV Specification
PRICE: PKR. 799,000/- (Ex- Factory)
Model CA6371A4
Emission Standards Euro IV
Dimensions Exterior Dimensions in mm (ft) 3741x1475x1870 (12.27x4.84x6.13)
Wheelbase (mm) 2450
Treads (F/R) (mm) 1280/1280
Ground Clearance (mm) 155
Angles (Approach/Departure) 27/28
Seating Capacity 6 - 8
Weight Curb Vehicle Weight (kg) 985
Gross Vehicle Weight (kg) 1585
Engine Engine Model DA465QA
Cylinders L4, OHC EFI
Bore x Stroke (mm x mm) 65.5x72
Displacement (cc) 970
Compression Ratio 10.0:1
Max Power PS/rpm 60/5200
Max Torque Nm/rpm 84/3000-3500
Transmission
Transmission Type
5 MT, Synchromesh
Chassis Clutch Single Plate, Diaphragm Spring
Minimum Turning Radius (m) 4.5
Steering Rack & Pinion
Brake System Disc (F), Drum (R )
Drivetrain 4x2 MR
Suspension System Front Coil Spring
Suspension System Rear Leaf Spring
Tyres 165/70R13
Capacity Fuel Tank (Liters) 37
Maximum Speed (km/h) 110
Features
Exterior Metallic Paint O
Front Fog Lamps S
Mud Flaps S
Projection Type Head Lamps S
Full Wheel Covers S
Outside Rearview Mirror (R & L) S
Interior Heater S
Seats Covers Fabric
Sun Visors S
Front Door Storage Pockets S
RPM Meter S
Digital Odometer S
4 Spoke Stearing S
Ashtray S
Glove Console S
AM/FM Radio S
Safety Features Front 3-point Seatbelts S
Rear 2-Point ELR Seatbelts S
Rear High Mount Brake Lamp S
Front Tow Hook S
Note: All specification & equipment are based on the latest information at the time of publication and subject to change without notice
