Toyota Corolla (E90)
The Corolla E90 was the sixth generation of cars sold by Toyota under the Corolla nameplate.
The performance option of rear-wheel drive was dropped after 1986, with all Corollas front-wheel drive from 1987, with production beginning in May 1987. For general export, the trim levels are Base, XL, GL, SE, and SE Limited. The GT-i was sold in limited numbers in certain countries. The all wheel drive Sprinter Carib wagon used a solid axle rear suspension with coil springs, while the rest used struts all around. The 4WD wagon was sold from 1988 to 1994 and had different bodywork to other Corollas. It was called the All-Trac in the US and sold with the Tercel or Corolla name in some countries. In general, all models depart from the previous generation's boxy styling, for a more contemporary look and improved aerodynamics.
The Sprinter five-door liftback was called Cielo in Japan, and re-badged as the Corolla in Europe, though for a period in Ireland (and possibly elsewhere) it was badged the "Sprinter GLS", unusually in cheap-looking decals instead of the metallic-coated plastic badges found on all other Toyotas of the time.
High performance GT-i models are powered by 4A-GE, and offered as 3-door hatchback, sedan, and 5-door liftback. The North American GT-S coupé shared the same engine.
Pakistan
The 6th generation of Corolla was imported from Japan and was available in only 4 trims. 1.3 and 1.5 liter petrol engines. As well as the 1.5 and 1.8 liter diesel engines. Only the four door sedan was imported. The 2-door coupe, 5-door wagon and the hatchback were not available in the showrooms. Because of the rising prices of gasoline, the 1.8 liter diesel powered corolla became a success immediately. The 2.0 liter diesel engine was not available until 1993 when the 7th generation was introduced, and it was the same time when Toyota started making cars in Pakistan. Even after the introduction of the 7th generation of Corolla, reconditioned 6th generation models were imported from the Middle East.
Model : Tomica limited
Scale : 1:64
