will try this.
there are also some other concerns.1- my gd's top speed is 80-85. after that it start screaming sounds.2- which chain+sprocket best. (its not for me its for friend's gd)3- it's clutch cable start losing very fast. often used to tight a bit. i used suzuki wrapping complete cable recently.
Slam...What shud b tyre pressure in front n back tyre?
como ago para conseguir el aranque
Dear TZB,
Recently i bought gd 110s and after driving for 120km i noticed that screeching sound is coming from the front wheel. Please advise what should i do to resolve this issue.
The sound may b coming from the tyre ... or bearing
Current reading on the odometer is 120km. So, should i visit mechanic for this issue or wait for another 100km?
Dear bro ... you should first consult the local tyre wala .. and balance your tyre and rim rubber seleve under the tyre (rim patti )and allign it with oil on tyre and balance it ... then drive the bike ... if around 2-4 km ...if the sreeching sound comming continues then it must the tyre fault 90% ..... except you already cross check the front wheel bearing
Today my New GD-110 got snatched..only 950 km done so far...
Ohh sad .... did you reported about snatching .... insured bike or not ...
Karachi? Aaj kal Suzuki ki bikes bohat snatch ho rhi hain karachi me. Pehle yahan sirf hondacg125 he badnaam thi is k liey but ab tou kuch bhi... Sorry for your loss bro
Yeah I reported in 2 hours and Got Temperoary FIR.It was insured as I did took it on lease From PAK suzuki.
But the process of Insurance claim is very cumbersome may take around 3 -4 months for return the payment
Yeah khi..Gulshan E iqbal block 13D
Lots of people says kay yeaH bike nahee Snatch hotee..But ab sab se zyada yehe. Snatch hou rahee
I understand it is too too late to reply now. But I'll reply.
Accept my apology for being inactive here, causing me to reply this late.
That noise might have been coming from unlubricated wheel assembly or failed wheel bearings.
It saddens me to know that.
May Allah give you sabar. May you get what you want. Aameen
I am using Zic M9 and it works well. Also genuine is easily available.
Hi, I bought a new GD 110.. I have used it for like two days and in running... I have noticed very small dents on the engine
Ya wala model esi colour ma mil skta hai kindly new same yahi chez
When to change oil filter. Currently, I'm changing engine oil and oil filter every 1000 kms.
